"-noDpiScaling" flag not working
Ravanelli
Post by Ravanelli »
I'm not if this qualifies as a 'bug' or not, but this flag used to work fine in version 1.11.7 when added to a shortcut,
but it doesn't work in the latest versions.
I hope that you can restore this functionality or integrate in the GUI.
Thanks.
Re: "-noDpiScaling" flag not working
there is no such flag in Qt6
I already told you what you can do
Ravanelli
Post by Ravanelli »
user0 wrote: Tue Oct 06, 2026 3:32 am there is no such flag in Qt6
Thank for replying.
Yes, I tried those already so I will reply here as well.
value: 0
value: 0.667
These apply the variables globally, which negatively affects other QT6 apps that I use such as VLC and qBittorrent.
Thank you.
This problem is supposed to be fixed in XnView MP 1.12.2. Please check and confirm the bug fix here.
