It looks like I'm guilty of fiddling with the "View" (maybe layout) and have now made some changes which I do not know how to undo. To be sure XnView MP has lots of capabilities. Unfortunately, this does increase complexity. Therefore, when experimenting with new options it seems natural to want to restore things to the way they were and start over. While this could be done by uninstalling and reinstalling the software it would seem natural for there to be a less intrusive method. After spending quite a bit of time trying/experimenting with various options I haven't been able to do it.
In my case, it seems that I managed to delete/disappear the frame at the bottom of the Window that displays metadata as well as other things.
While I hope it is simple I'd be grateful for some help figuring out how to restore the original view/layout.
Restore Default View
Re: Restore Default View
rename xnview.ini
ajax
Ok, but it looks to me like that will also reset a lot of other things. I was hoping there was an easy way to just restore that aspect of the windows layout. With that said, it also looks like it would be good for me to learn how those features are intended to work. If anyone could refer me to some documentation that explains how it works that would be quite helpful.
'View>Title bar'?
bugreporter
It is simple, indeed: Go to "View", "Panels" or "Info panels" and choose whatever you want to see. Or you can use of the predefined layouts in "View", "Layout" - but this also might result in unwanted changes.ajax wrote: Fri Oct 09, 2026 2:22 pm ...
BTW: You can save (and restore) up to 5 own layout settings, in the "Toolbar 1", menu "Layout". Good for experimenting with layouts.
And generelly speaking: Don't you make backups of important data, including user profiles? You should, of course. Then you just could restore the XnViewMP profile data, or only xnview.ini, if necessary.
