Last Version 1.10.5 on Debian 13 : OK
Copied all files from the 1.12.2 targz archive : Not Starting .
deleted user files .db etc....: Not starting
Starting .sh File : Crash of terminal : terminal close itself ! never seen on debian 13 ! whats going on!?
and no output.
Starting from old DIR 1.10.5 : all working again.
In earlier versions there was a evertime an output ( the .so , plugins , PATH and missing things problems....)
Is it gone? Why?
Where can i find a log file? start with debug modus?
I can find no infomation what linux version you support , but you sell the software to companies?
There is only one : ubuntu/debian 11.5+
What does that mean?
Is Debian 13 / 14 supported?
11.5 is not supported from debian . it is too old. End of Support : 15 August 2024
I would suggest to write a check script,that customers can check, if something is missing, and you too.
And in future you must not answer so much questions in the forum : "what output do you see in terminal " etc....
As this targz ist not stable working, as debian.org is normally checking very good before an update , I will
say 1.12.2 is not stable and you should invent a better quality management and better documentation for linux OS.
e.g. old/stable/testing
and a install.sh for a better setup , checking missing things, before crash.
Latest update xnviewMP 1.12.2 on debian 13 not working
linux23
Re: Latest update xnviewMP 1.12.2 on debian 13 not working
Try to set
before to start XnView to have information?
QT_DEBUG_PLUGINS=1
