How do you zoom-in on both images simultaneously in Compare without repositioning, that is, even if they've been repositioned, without using a mouse, for example on laptop? I was hoping it could be done by remapping Zoom In to equal-sign then using shift-equal-sign but the remapping doesn't work. Zoom-in still requires plus-sign even though equals-sign is definitely shown as registered! For both Viewer and Browser.
Description of the mouse version of what i'm asking for is at viewtopic.php?t=44392
1.11.7
Zoom-in at fixed place without mouse (do not reset images position when zooming)
turtle
jkm
Re: Zoom-in at fixed place without mouse (do not reset images position when zooming)
You answered your own question. + zooms in when using Compare. Remapping it doesn't work in Compare.
If this is primarily about positioning when you have independently repositioned the images in Compare, like in that other thread, then please participate in that thread instead of duplicating.
