XnView MP - 1.12.3 [10346] 64-bit (Nov 9 2026) Libformat 7.314 (Windows), Win 11 Pro (fully up to date)
When i change the "View As" option from "Thumbnails + labels" to "Thumbnails + Details"
different exif data is shown,
For Thumbnails + labels , i set it to show me the date taken, which is the most important date for my organization.
But in the Thumbnails + Details it shows the date modified.
Is this normal operation or am i missing a setting somewhere.
James
View As help
james515
View As help
jkm
Re: View As help
Welcome to the forums, James.
From the nature of your question, it seems that you are new to the application.
View Thumbnails+Labels is configurable; you can change the information displayed in Settings:Thumbnail:Labels, as it seems you have discovered.
View Thumbnails+Details is not configurable. What you see is what you get.
However, if you really want to use Thumbnails+Details, and yet still have some additional configurable information, you can do this with Tooltips.
Configure what you want in Settings:Browser:Tooltip, and when you hover over a file with the mouse, the tooltip with your information will appear.
If you want configurable information at a glance without needing tooltips, you will need to get used to the Thumbnails+Labels view. There is also Details view, which can display a wealth of info in a sortable, tabular form, but without thumbnails.
Hopefully this helps...
james515 wrote: Fri Nov 27, 2026 11:47 pm When i change the "View As" option from "Thumbnails + labels" to "Thumbnails + Details"
james515
Re: View As help
jkm wrote: Sat Nov 28, 2026 12:36 am Welcome to the forums, James.
Umm, I have been using XnView since 2008, so not new to it. But i just created a logon so i could ask about it.
I have searched the forums previously , but i guess my search query words did not match any post or info in the forum.
I was just curious of the Thumbnails+Details , because i could NOT find any documentation on it, as the documentation is scattered about
99% of the time i just view Thumbnail:Labels because i configured it for my liking. but it is just odd that the Thumbnails+Details view shows a different date than the EXIF: Date taken in the Thumbnail:Labels
the straight details view is useless for me with out a thumbnail of the image. yes it is a wealth of information but useless without the thumbnail. and thats all just my personal preference
jkm
Re: View As help
Ok, well sorry to hear your search wasn't fruitful. I'm not sure how you searched, but the answer to the question doesn't seem difficult to find. A google search for "xnviewmp configure thumbnails details" gives these two threads as the first search results:
viewtopic.php?t=51040
viewtopic.php?t=36038
And using the forums search also returns one of those right at the top of the results. But generally I think a google search returns more useful results than the forum search.
As you noticed, there's essentially no documentation for the app. There are a few quite old tutorials, and I've been documenting the new features added over the last year or so, but unfortunately there's little else. So, other than experimentation, searches are the primary resource for people, and naturally a lot of questions get duplicated. Obviously other people have also wondered about the lack of configuration for Thumbnails+Details. Perhaps something can be done for a future release.
Anyway I'm glad you have your question answered. You're welcome... Cheers!
