Thumbnail View Labels: Filename not shown
negg
Post by negg »
Hi Pierre,
In 1.82.2 I noticed that in "Thumbnail & Labels" viewmode the filename is not displayed, even with option "Show filename in thumbnail mode" ticked.
I can add the filename to the list of labels, but when I put it as the first of, say, four labels I can't change the name by clicking on the name label, as before. Only clicking on the last of the four labels lets me edit the filename, but the small edit field shows up at the bottom of the label stack...strange. See example screenshot.
Martin
XnView 1.93.4 on Windows XP SP2
marsh
Re: Thumbnail View Labels: Filename not shown
Post by marsh »
negg wrote: I can add the filename to the list of labels, but when I put it as the first of, say, four labels I can't change the name by clicking on the name label, as before. Only clicking on the last of the four labels lets me edit the filename, but the small edit field shows up at the bottom of the label stack...strange. See example screenshot.
Confirmed. The mouse input field is not always over filename label. It drifts downward when more labels are added.
Dreamer
Post by Dreamer »
negg wrote:Hi Pierre,
That option is just for Thumbnails view. You can customize "Thumbnail & Labels" view in options > thumbnail > labels. So no bug here (IMO).
negg wrote:I can add the filename to the list of labels, but when I put it as the first of, say, four labels I can't change the name by clicking on the name label, as before. Only clicking on the last of the four labels lets me edit the filename, but the small edit field shows up at the bottom of the label stack...strange. See example screenshot.
Martin
Confirmed - a bug.
Yes, a problem with windows listview control :-( Use F2
