New to XnView.. Can someone help me on disabling the File tool bar that contains the 'Save as', 'Save', 'Print', 'Edit'? Just want to view, zoom, rotate.. Any suggestions with this..
Thanks
Byron Balasco
Disable 'Save as', 'Save', 'Print'
Re: Disable 'Save as', 'Save', 'Print'
Sorry, disabling editing and saving is not possible at the moment.BYRON BALASCO wrote:... Can someone help me on disabling the File tool bar that contains the 'Save as', 'Save', 'Print', 'Edit'? Just want to view, zoom, rotate.. ...
There are the so-called 'Hidden' options to hide specific menu items and options, but these are intended for terminal environments, not for disabling main functionality like editing and saving images.
BYRON BALASCO
As crazytb wrote above, you could remove the appropriate items in the toolbar ('Tools->Options', Category 'Toolbar'). But there are not options to disable (=remove) the functionality completely, i. e. in the toolbar and the menu.BYRON BALASCO wrote:I just don't want someone to be able to view rotate and save a .tif. on exiting the xnview program.
So currently, XnView cannot be limited to a 'Viewer'. Perhaps you can make the TIF files read-only and thus prevent users from changing them.
