Status bar - wrong information
Dreamer
Post by Dreamer »
If [..] item is enabled, number of objects is wrong in status bar, e.g. if there are 6 images (and [..]), it displays "7 object(s)".
Normal...
:) Hi !
- Like you say yourself, it displays nobjects, and not n… image-files
- So, “••” is a kind of directory for Windows, hence an “object”…
- No bug there, IMHO, but indeed the count of image¦other files types only could be got from an Option, if Pierre can do this (he might…)
:mrgreen: KR
Olivier_G
Post by Olivier_G »
A Bug, in my opinion: ".." is not an object. It is simply the representation of a command to go up one level.
Olivier
ckit
Post by ckit »
There is no bug.
Closed.
Olivier_G
Post by Olivier_G »
ckit wrote:There is no bug. Closed.
Huh??? Is that some kind of Moderator-wanabee Superpower?
I'll try the magic formula: "There is a bug. Open!"
Waouh... it works... :mrgreen:
Olivier
Bluup !
—> Olivier_G
:) Hello !
•Bill Gates and I disagree totally, like you can see below :
———Image
- It's in French, so : <REP> = <DIR>
- “ • ” and “ •• ” are directories for Windows, so "objects" :P
:mrgreen: KR
Olivier_G
Post by Olivier_G »
Right.
...but if you consider some standard Windows applications like WinRar or Total-Commander, you will notice on those screenshots that ".." is never included in the object counts (not considered as a Directory nor as File).
And I am not nitpicking: I really believe that most Windows programs that show ".." and provide objects number never take this ".." into account.
Olivier
One more, one less…
:D Olivier, I use Total Commander for almost ten years too, I'm the official French translator and more…
- I guess it's a choice, according to the personal tastes of each author… So, maybe Pierre likes more the strict DOS point of view, while E. R. and Ch. Ghisler consider this in a more flexible state of mind - though TC is very close of the DOS still, even too much for many users-.
- Moreover, TC says “ n… files”, not objects ! So, everybody is right !
- So, finally, not a big deal, this could be solved easily by an INI option like :
CountParentAsObject = 1 ¦ 0
1 : Yes
0 : No
:mrgreen: KR
[OT] :shock: TC "Not registered" !
Image Shame on you ! Image
Dreamer
Re: One more, one less…
Post by Dreamer »
It's a clear bug for me.
1. It would not be useful for anyone to count [..] as object.
2. [..] cannot be an object, because it's not on your hard drive = it doesn't exist.
ckit
Post by ckit »
Actually, it does exist as part of the "File and Folder" Structure of the Hard Drive.
Olivier_G
OT
Post by Olivier_G »
Clo wrote:Olivier, I use Total Commander for almost ten years too, I'm the official French translator and more…
I know: this is exactly why I chosed this example (and WinRAR for ckit... :mrgreen:): I knew they would be more persuasive... :wink:
Clo wrote: :shock: TC "Not registered" ! Shame on you ! Image
Hey! I am not the owner of Softpedia yet... from which that screenshot was shamelessy linked... :P
Olivier
ckv
Post by ckv »
When Bill Gates says jump, you will jump or bare the consequences...
What? ... No I didn't read the topic and you should ignore all contents in this post. But for my defence I must say that i saw somebody talking about Bill Gates.
ckit
Post by ckit »
ckv wrote:When Bill Gates says jump, you will jump or bare the consequences...
I'll take my chances :)
Dreamer
Post by Dreamer »
What about this?
For example, in FreeCommander - file manager, this information is correct, any chance to fix it in XnView? It's quite confusing, especially when I see different numbers in these two programs...
Dreamer
