How can I add Xnview to my file extension list?
Little Bittern
Post by Little Bittern »
I want my computer (Win XP) to automatically open my pictures with XnView, but it tends to be stuck on the Windows-viewer. In Windows Explorer, where I try to alter the default programme with wich I want to open my pictures, several different programmes appear in the list exept for Xnview. Does anyone know how I can add the programme? Thanks!
LB
Re: How can I add Xnview to my file extension list?
Little Bittern wrote:Hi,
LB
You can use options/Associations
Post by Guest »
LB
Thank you very much. I feel a bit dumb for not finding that out for myself, though. But I guess I figured that this would be a default setting. Thanks, anyway, Love your programme!
Dreamer
Post by Dreamer »
Perhaps it could be added to tip.ini. What do you think?
There's an FAQ "How to associate image files with XnView".
Dreamer wrote:Perhaps it could be added to tip.ini. What do you think?
Very good idea. I've just made a suggestion in the XnView Wiki, feel free to change the wording to improve it (#106).
