Command-line-option -slide <directory>
tom*de
Post by tom*de »
we discussed about an useful command-line-option for xnview in the TC-Forum: http://www.ghisler.ch/board/viewtopic.php?t=10192
xnwiew -slide <directory>
z.B.:
xnview C:\PICTURES\
A) Starts a slideshow with all the files in a directory...?
It should use the slideshow-options in xnview.ini.
B) The same behavior would be useful if the slideshow-file <file.sld> only contain a list of filenames...
Re: [Request] Command-line-option -slide <directory>
Hello tom*de,
your post was in the wrong forum group, this is why it hasn't replied to, yet.
tom*de wrote:...
I like the idea of a command line option which allows for starting a slideshow of all images in folder. I guess -slide is occupied, perhaps something like -slidedir would be possible.
tom*de wrote:B) The same behavior would be useful if the slideshow-file <file.sld> only contain a list of filenames...
Also a useful feature. Generating a list of filenames can be performed easily, would be really useful to be able to simply pass the filelist on to XnView to display a slide show.
tom*de
Post by tom*de »
Hello Helmut,
sorry for the wrong posting.
Thank you for your positive answers - we are looking forward to these features.
Tom*
Re: Command-line-option -slide <directory>
tom*de wrote:Hello,
z.B.:
xnview C:\PICTURES\
Ok, i'll add -slide for a folder too :-)
Post by Guest »
I'd love that if you've "xnview -slide filename.jpg" that would also start the slideshow with default options starting with filename.jpg... wouldn't be too hard to implement but will save my day!!!
Great work!!!
