ECW Format and xnview 1.82.4
hackel
Post by hackel »
I don't manage to view ECW format ?? I've got the last version of xnview and GFL SDK v2.54.
Is it impossible ??
Plugin---
—> hackel
:) Hello !
• The ECW format is supported -read and write - but needs the Wavelet plugin.
- Please, get it from the XnView site (there is an archive containing all plugins to download) and place it in the <Plugins> sub-directory of the programme.
- You can know which formats are supported by the programme >> Info menu, or better directly here where you can get them sorted by extensions. ;)
:mrgreen: Kind regards,
hackel
Post by hackel »
I finaly found it but it does'nt work :|
My ECW's file are from ECW compressor 2.2
>> Forum FR
:) Hello !
- We could continue that topic in the French forum, and then Pierre'll inform you certainly… The other Members can't read here in French (the most…).
:mrgreen: KR
As Clo has pointed out already, you need the ECW plugin for XnView for reading the ECW files. I've installed the plug-in just very recently and it does work (XnView 1.82).
A special issue…
—> helmut
• Hi !
- The discussion about that issue is continued in this French thread.
- In brief : Although hackel has installed the plugin alright, that doesn't work anymore…
- Hence, we are waiting for the Pierre's opinion, maybe the issue is the 2.2 version of the ECW compressor, so Pierre needs a sample, and an updade of that plugin could be necessary, perhaps.
- Anyway, we'll report the progress about that problem here (if any…), because I guess that's interesting for all users.
:mrgreen: G.
