Set jpeg comment
Kasper
Set jpeg comment
I just can't find the 'jpeg lossless comment' option from the 'Jpeg lossless transformations' menu. The jpeg comment shows fine at properties popup, but I cannot edit it there. Version is 1.82.4 installed to a fresh computer with windows xp.
Re: Set jpeg comment
In Edit/MetadataKasper wrote:I just can't find the 'jpeg lossless comment' option from the 'Jpeg lossless transformations' menu. The jpeg comment shows fine at properties popup, but I cannot edit it there. Version is 1.82.4 installed to a fresh computer with windows xp.
