Space bar in browser .. go to next thumb?
klaus2
Would be nice: in browser (on a thumbnail) space bar acts as "go to next thumb" (like right arrow key).
That would allow an equivalent navigation like in viewer, where it is possible to have "space bar for next image".
Currently the space bar is not used, so alternatively i could imagine a "space bar = show image in viewer" (like with enter key).
What do you think?
Best Regards,
klaus2
What do you think?
Best Regards,
klaus2
Re: little suggestion: space bar in browser .. go to next th
In Option/View/Keyboardklaus2 wrote:Hello,
klaus2
klaus2
Hello!
The other feature suggested obviously refers to space+insert ...
Nothing against the arrow keys
but consistently space bar for 'next image' (viewer) and 'next thumb' (browser)
for me sounds to be intuitive .. and space bar is near to reach ..
Of course it's a very small thing, i know, but actually the space bar is not used.
Best Regards,
klaus2
Best Regards,
klaus2
Not space+insert but space AND insert, means both keys, same as in file managers.klaus2 wrote:The other feature suggested obviously refers to space+insert ...
So it would be better also to select images then.klaus2 wrote:Nothing against the arrow keysbut consistently space bar for 'next image' (viewer) and 'next thumb' (browser)
Maybe an option, same as in fullscreen...
klaus2
klaus2
If…
—> klaus2
Hello !
• Indeed, it should be quite handy.
- However, I don't know whether it could be configured both for the browser and for “View” … ?
- If it should, I support !
Kind regards,
Re: If…
Currently i can't for the browser...Clo wrote: - However, I don't know whether it could be configured both for the browser and for “View” … ?
