No thumbnails in Total Commander
joro3d
Post by joro3d »
Hello
Thank you very much for adding the ICN format to XnView :D
I have a strange problem using it in Total Commander though...
When I switch to thumbnail mode in Total commander (Ctrl+Shift+F1) the ICN files don't appear with their correct thumbnails.
Instead I see the default icon for them. Same happens with .*INT, *.INTA, *.RGBA images (*.RGB and *.SGI are OK)
Could you please support me with a solution to that? :(
Thank you
P.S. A screenshot:
RTFM
:) Hello!
• Please, just read this : http://perso.wanadoo.fr/charries/xnv/en ... b.htm#team
- The entry IviewAdditionalTypes= doesn't exist by default, you must add it since obviously you don't know it…
:mrgreen: Kind regards,
joro3d
Thank you
Post by joro3d »
Wow! :D
Thanks so much! I really love it!
George
joro3d
Post by joro3d »
Hello again,
I reinstalled windows XP. I use latest Total Commander and latest XnView. But ICN files stopped showing in Total Commander. I have done what you explain in your previous advice - but this time it didn't work... any ideas? :(
joro3d
Post by joro3d »
Something more:
ICN files no longer show even in XnView itself...?
joro3d wrote:Something more:
And you had them before on 1.90.3???
joro3d
Post by joro3d »
the problem is on my office machine
it is very strange, because i still have them on my home machine - which has the same version of both softwares. @home i can see ICN thumbs in total commander and it's ok
what could be done?
Sample ?
—> joro3d
:) Hello !
• Please, could you post a link to get an *.ICN file to test, I've not any à home…
• I have the newest version of Total Commander (an even newer than yours for some reasons ;) ) and XnView 1.90.3
• Note : I updated the link to the Manual in my old post above because it was a bit changed…
:mrgreen: KR
joro3d
Post by joro3d »
Strange i can view them....
Partially confirmed
—> joro3d
:) Hello !
• The fault seems to be in TC 7, since I can display your images in XnView 1.90.3 here, like Pierre says :
• It works as thumb nails in TC 6.56, but NOT in TC 7 RC 1.x
• Indeed, I've associated the *.icn format with XnView 1.90.3 and added the extension in the <wincmd.ini> [Lister] –>
IviewAdditionalTypes=… *.icn like one ought.
- You might post in the Public beta test TC forum HERE, and the Mod (myself) shall confirm ! :D
EDIT : Yep ! I had to set the *.icn type in the Options >> Thumb nails for XnView ! Now, that works !
:mrgreen: KR
joro3d
Post by joro3d »
That is very strange as I said, because on my home machine I have no problems (yes, it works in TC7 RC1!)
It's only on my office machine. Could this be because of different hardware?
Office machine is:
pentiumD Dual Core 3GHz
nv7800 agp
Home machine is:
dual Xeon 2.4GHz
nv Quadro FX560
The problem is on the office machine. It is strange that it appeared after changing the mainboard and CPU (it was p4 single-core before...) Do you think XnView has problems with dualcore?
joro3d
Post by joro3d »
any help?
