Can not get full screen view!
Post by Guest »
I have been using XnView for long time, and there was no problem....but suddenly i cant get the full screen view, around 25-30 pixel gap is always there on top with a part of the current image,
earlier pressing esc. used to exit the full screen mode, that also is not working...
i tried installing the latest version yesterday...but it did not work..
what should i do?
i would appreciate any help
Re: Can not get full screen view!
Anonymous wrote:I have been using XnView for long time, and there was no problem....but suddenly i cant get the full screen view, around 25-30 pixel gap is always there on top with a part of the current image,
what should i do?
Is it possible to make a screenshot?
Post by Guest »
tyhanks for the reply, :)
i'd post some screen shot as soon as i can :)
thank u
