I've been using xnview on a sony vaio laptop running NT 2000 (sp4 final), and liked it a great deal. I recently upgraded to a Dell Inspirion 1300 also running NT 2000 sp4 final, installed xnview (1.82.2), and now I have a problem. When I double-click on an associated file in Windows Explorer (say a .jpg, but any filetype acts the same) the program runs, but it does not display. I know it is running because I can see it on the process listing of the task manager (however, not on the applications page). I upgraded to the latest version, 1.82.4, same thing. Uninstalled and reinstalled, same thing.
However, drag/drop a file onto the xnview icon, works fine. Use the File/Open menu from inside xnview, works fine. Use the Send To menu, works fine. The "Browse with xnview..." option for folders works fine as well.
Once again, the machine is a Dell Inspiron 1300 notebook, 512 mb ram, intel 915 video, running win2k sp4 final.
This seems like an odd one. Hope someone can help. Thank you,
Tom Asbury
Double-clicked file does not display
tasbury
FAQ "How to associate image files with XnView" might help.
tasbury
Ran xfam, updated associations, now neither double-click on a graphics file, nor
send-to work. Association text seems ok:
"c:\Program Files\xnview\xnview.exe" "%1"
Once again, drag/drop, file/open, "browse with xnview..." on folder, all work.
Process is running but application not listed...
Also (persuant to Helmut's post) tried re-associating inside xnview. No change in program behavior. I was beginning to suspect that this is a problem in command line parsing, that applies to my dell running nt 2000 that somehow does not apply to the vaio running the same o/s.
However, when I run xnview from the command line, eq:
"c:\Program files\xnview\xnview.exe" c:\copy\helloworld.png
it comes up fine. Running it similarly from the "Run..." dialog in the Start button works too.
Of course, now that I restored the file associations from inside xnview, I can't look at the association text from inside windows explorer on the Tools/Folder Options/File types dialog.
marsh
Re: Double-clicked file does not display
Make sure the command line window's registry uses for 'open with' does not have "-slide" in it.tasbury wrote: This seems like an odd one. Hope someone can help. Thank you,
The following topic should help:
http://newsgroup.xnview.com/viewtopic.php?t=3549
tasbury
Gotcha!
Right On, Marsh. Works now.
That doesn't explain why it worked with nt2k on the Sony but not on the Dell, but now that I think about it, the Sony was an upgrade from oh, what, 1.80.0, I think. The registry key was no doubt already in place. and probably not changed during the upgrade.
Thank you all,
Tom
Thank you all,
Tom
