Image description - focus disappears
Orictes
Post by Orictes »
Each time I describe image with Ctrl+D, cursor disappears and I can't continue on next img. What's wrong?
ckit
Re: Img. description - cursor disapears and I can't continue
Post by ckit »
Orictes wrote:Each time I describe img. with Ctrl+D, cursor disapears and I can't continue on next img. What's wrong?
I'm using XnView v1.70 RC3 with Win2k SP4 and do not have this problem. However when I type in the description box the mouse pointer disappears and re-appears when I move the mouse but I think thats normal.
Orictes
Post by Orictes »
...no, it is not. Cursor disapears and after pressing a key it is on a parent directory position [..]. It's evidently bug, it is almost impossible to do descriptions in directories with a lot of pictures. I have to use ACDSee instead.
ckit
Post by ckit »
Orictes wrote:...no, it is not. Cursor disapears and after pressing a key it is on a parent directory position [..]. It's evidently bug, it is almost impossible to do descriptions in directories with a lot of pictures. I have to use ACDSee instead.
Hmm. what keyboard and mouse software do you have installed? I have IntelliPoint v4.12 and IntelliType Pro v2.1 installed.
Post by Guest »
... the problem doesn't depend on the mouse at all. Ctrl+D on a picture, typing description and Enter and then picture is deselected and after pressing any key a parent directory [..] is selected instead of the same or next picture. Sorry for the term "cursor" I've meant the "selected picure" (keyboard cursor).
ckit
Post by ckit »
Anonymous wrote:... the problem doesn't depend on the mouse at all. Ctrl+D on a picture, typing description and Enter and then picture is deselected and after pressing any key a parent directory [..] is selected instead of the same or next picture. Sorry for the term "cursor" I've meant the "selected picure" (keyboard cursor).
After I enter a description for an image the image stays selected and I can then move on to a another image.
Are you using XnView v1.70 RC3 or v1.68.1?
Orictes
Post by Orictes »
ckit wrote:... Are you using XnView v1.70 RC3 or v1.68.1?
... both of them, it's strange... I tried it on another computer and it's the same.
ckit wrote:After I enter a description for an image the image stays selected and I can then move on to a another image.
I have not the problem too.
Which OS?
Orictes
Post by Orictes »
Which OS?
WinXP Pro SP1 (Czech version)
After using Describe dialog box, the focus is no more on the thumbnail view?
Orictes
Post by Orictes »
Now I can simulate this problem. Go to 'Options - Browser - File list' and uncheck option 'All other files'. If I let it checked, everything is OK. Try it and let me know please.
ckit
Post by ckit »
Ok, now I can re-produce this :bugconfirmed:
ckit wrote:Ok, now I can re-produce this :bugconfirmed:
I can't :(
Pierre
Orictes wrote:Now I can simulate this problem. Go to 'Options - Browser - File list' and uncheck option 'All other files'. If I let it checked, everything is OK. Try it and let me know please.
I've just tried and could easily reproduce the problem - both on Windows XP SP1 and on Windows 2000 (no SP). When confirming the dialog the focus moves to 'nowhere'.
Pierre, on the option page there's two settings for 'All other files', did you uncheck the one in the frame 'Item shown in thumbnail mode' (just to make sure)?
Some more details:
- It doesn't matter if you use the mouse or keyboard.
- If you cancel the dialog 'Description', the problem does not occur.
helmut wrote:I've just tried and could easily reproduce the problem - both on Windows XP SP1 and on Windows 2000 (no SP). When confirming the dialog the focus moves to 'nowhere'.
I've tried again with the 1.70, and the focus is back on the thumbnail list.
No checked
Very strange.
