Hi!
I've been trying to convert some jpeg files to mbm format, but the xnview nconvert) doesn't allow me to save the files in other format than 16 level grayscale.
I wonder what could be wrong ?
And there is one other thing; the files that I've converted to the grayscale do not show on my 9210i. The device just complains about buffer overflow.
AFAIK the MBM format is the same on both devices, the psion 5 and 9210i or am I completely wrong ? (Though the psion doesn't have a color display!)
Regards;
Mikko
MBM files in 24bit/8bit Colour format
Re: XNview and MBM files in 24bit/8bit COLOR format.
Could you send me some samples in 8 & 24bits?dxrd wrote:I've been trying to convert some jpeg files to mbm format, but the xnview
(nconvert) doesn't allow me to save the files in other format than 16
level grayscale.
I don't know, but do you have sample of MBM for 9210i?And there is one other thing; the files that I've converted to the grayscale
dxrd
That's the problem - I can save (any) graphic in 16 color gray, but the other possibilites are just "shadowed out" that I can't eves select them.
I've tried numerous pictures, each time with the same result
Maybe, there was some sample pictures installed in the 9210i. (though I've already deleted them.) I'll check through the nokia website and the CD that was supplied with the phone.
Mikko
Mikko
dxrd
Damn... the files seem to be stored in the flash memory of the 9210i, so I can't undelete them, unless I reset my 9210i, which I don't want to do!
If you somehow could extract contents of some .SIS file, there would be
plenty of MBM data to examine!
Mikko
Mikko
dxrd
Hey! I found ONE mbm file from the system folder of the 9210i. It's a picture of a folder... size 2 kb
I can send this one to you, if it's any use to you
Mikko
Mikko
Yes, please.dxrd wrote:Hey! I found ONE mbm file from the system folder of the 9210i. It's a picture of a folder... size 2 kb.
> Yes, please.
> Pierre.
Alright then. How do I send it to you - as an email attachment ?
Sorry that the answering took so long - I'm currently studying, and I don't have a PC at the dormitory , so I'll have to use the PCs at my school.
Mikko
> Pierre.
Mikko
dxrd
I sent you two emails and few sample files reagrding the issue.
I hope the address was right =)
Mikko
Mikko
dxrd
Hi! Any progress with the MBM files ?
Regards;
Mikko
Regards;
Mikko
Sorry i have not yet check.dxrd wrote:Hi! Any progress with the MBM files ?
