I have a load of images that i want to convert to convert to colours and then recolor two colours. I can batch convert to color no problem. However I can't see how I could change the colors which i would do manually by using the Image --> Edit Colormap functionality. Is it possible to use the Edit Colormap functionality in batch mode?
Thanks
Paul
Batch Convert: Is Edit Color Map possible
connollypaul
Re: Batch Convert: Is Edit Color Map possible
Currently you can't edit colormap in batch convert...connollypaul wrote:I have a load of images that i want to convert to convert to colours and then recolor two colours. I can batch convert to color no problem. However I can't see how I could change the colors which i would do manually by using the Image --> Edit Colormap functionality. Is it possible to use the Edit Colormap functionality in batch mode?
connollypaul
