JPeg 2000 images distorted or not displayed
canis
Post by canis »
thanks for your fine program! I am using Version 1.70.2 on Windows 2000.
I archive my pictures using JPeg 2000. When trying to browse them with xnView I get only distortions in some cases in other cases I get nothing. When trying to browse with IrfanView, I can see the pictures without problems.
The files are created using PhotoShop CS with jp2 compatibility set to yes.
Re: Problems with jpeg 2000
canis wrote:thanks for your fine program! I am using Version 1.70.2 on Windows 2000.
Which plugin do you have? Luratech (lwf_jp2.dll) or Xjp2.dll?
Could you send me a sample?
Post by Guest »
For what program do you ask for?
Let me try for both:
Photoshop: JP2KLib from Adobe
IrfanView: JPEG2000.dll based on SDK from Luratech
Sure, I'll send you some different samples. Just trying to get some neat little ones.
xnview wrote:Which plugin do you have? Luratech (lwf_jp2.dll) or Xjp2.dll?
Pierre means the plug-ins used/installed in XnView. You can find out via menu 'Info->Plug-In Information' in XnView.
canis
Post by canis »
Thanks. I just looked: They do exist both. I found out more in the meantime:
It works with 8-Bit-color depth and extension .jp2 It does not work with my favorite 16-bit color depth.
I just send the files.
Thanks for your help!
canis wrote:It works with 8-Bit-color depth and extension .jp2 It does not work with my favorite 16-bit color depth.
Only Lurawave jpeg 2000 plugin works with 16bits per channel!
canis
Post by canis »
xnview wrote:Only Lurawave jpeg 2000 plugin works with 16bits per channel!
So there is no chance, that you support it? I thought it is one of the main advantages of jp2.
Sorry, but if so, I will go on using vallen jpegger for my browsing, because I can not see an advantage in using XnView for me, only the disadvantage, that I can not write the cache to CD.
Remove Xjp2.dll and use lwf_jp2.dll plugin
Post by Guest »
[quote="xnview]Remove Xjp2.dll and use lwf_jp2.dll plugin
Pierre.[/quote]
I removed Xjp2.dll, but it still does not work with the examples I send to you. Is there any trick how to "use" lwf_jp2.dll ?
Anonymous wrote:I removed Xjp2.dll, but it still does not work with the examples I send to you. Is there any trick how to "use" lwf_jp2.dll ?
Ok, it's a bug with lwf_jp2.dll, i fix it.
canis
Post by canis »
xnview wrote:Ok, it's a bug with lwf_jp2.dll, i fix it.
Many thanx!
canis
Post by canis »
Thanx for the wonderful new Version 1.70.3 !!!
Now I can view my jpeg files with 16-Bit-Colors!
The only drawback I can see is that only files with extension jp2 are handled, but not the files with extension jpf. Do I have to do something so that they are also recognized? If making batchprocessing in PaintShop it insists in using the non-standard extension jpf on output. I may rename them all, but that is a little bit annoying.
canis wrote:The only drawback I can see is that only files with extension jp2 are handled, but not the files with extension jpf. Do I have to do something so that they are also recognized? If making batchprocessing in PaintShop it insists in using the non-standard extension jpf on output. I may rename them all, but that is a little bit annoying.
Ok, i add jpf for lurawave plugin.
