scanned files not saved
Rolf Wiegand
Post by Rolf Wiegand »
I am using a HP scanjet 5590 with the HP commercial driver and Windows XP professionell. Using XNView with a restricted user, I first got an error message that file c:\scan1.jpg cannot be saved. After granting full access to c: this error message is gone. Now scanning seems to work at first sight, but although no error messages appear, the scanned files are not saved. I have no idea, whether the problem is caused by XNView or the HP driver or something else.
Changing the user to admin-rights everything works perfect.
I appreciate any solution to solve the problem or to track it down.
Thanks a lot
Rolf
Re: scanned files not saved
Rolf Wiegand wrote:Hi,
Thanks a lot
Rolf
Do you use the batch scan or scan?
Rolf Wiegand
Scan
Hi Pierre,
I use File - Scan into. I do not know whether this is scan or batch-scan.
Re: Scan
Rolf Wiegand wrote:Hi Pierre,
It's batch scan, but the scan works? Only a problem for saving?
Rolf Wiegand
scan files not saved
Hi Pierre,
the scan works fine with single originals and automated document feeder. No error messages occur. After the scan is finished, no files are saved in the destinated folder.
Re: scan files not saved
It's very strange, and all works in user account?
Rolf Wiegand
Hi Pierre,
if the user account is a administrator account everything works perfect. After changing this user to a restricted user account with full access to volume c: the problem with the not saved files occurs.
Very strange, and do you have tried on another folder??
Rolf Wiegand
Problem persists
Hi Pierre,
I tried to save files in another folder an in another logical volume. No success, the problem remains the same.
Re: Problem persists
And could you try to save a picture in this folder with xnview?
Rolf Wiegand
Files not saved
if I save a file from XnView in that folder it works.
