Burn CD with Slideshow
green55
how can i burn cd with sld 2 a friend that dont have the softwear on his computer?[/quote][/list]
dino
Re: burn sld
You can't directly burn sld, you can burn slideshow (from sld)green55 wrote:how can i burn cd with sld 2 a friend that dont have the softwear on his computer?
green55
Re: Burn CD with Slideshow
You can either burn a CD withgreen55 wrote:how can i burn cd with sld 2 a friend that dont have the softwear on his computer?
a.) The images, XnView, and the .sld file
This is described in the XnView Online help.
b.) Generate an executable slideshow (*.exe).
In slide show dialog ("Create > Slideshow"), select "Create EXE/SCR" button to create one executable file containing the slide show and all your images.
