File selection disappears when moving file with Alt+M
LastZolex
Post by LastZolex »
First of all: XnView is *the* greatest freeware picture viewer I know, thank you for sharing it with us! ;-)
I have only one annoying problem with all versions up to 1.70.4.
When I select a couple of files from the browser and use Alt+M to move them to another folder, after moving the files, the cursor jumps right to the top of the list, which is not very helpful in most cases ;-)
The effect can be reproduced always, even if the 'Synchronize Browser Selection with current View' option is checked.
It does NOT happen, if I simply delete a file!!
I haven't found any mentioning of this error here, so I thought it would be worth throwing it it ;-)
oh, btw, it would be nice if Alt+M would always show the last used directory (and not the last selected via "...") as default, but this is only a "nice to have" ;-)
have a good time out there
Last Zolex
LastZolex
Post by LastZolex »
Hmmm, unfortunately nobody else seems to have the problem or knows what I mean...
BTW, the error occurs with Windows XP professional SP1.
Well after some research I found out that, on another computer with Windows XP Home SP1 and version 1.61 of xnView, the error does not occur! There it does what I expect when using Alt+M: the cursor stays at the next possible position after the moved files.
Is it possible that it is an issue with 1.7x ?
Or is it just me?
Thanks for any advice.
LastZolex wrote:Hmmm, unfortunately nobody else seems to have the problem or knows what I mean...
You've been simply a bit too quick - it was week-end and all newsgroup members went out for party. ;-)
I could reproduce your problem on Windows XP:
Some important additions to your problem report:
- In the browser you choose a folder with many files, so that vertical scrollbars for the file list are shown.
- Scroll to the bottom of the file list and move one or several image at the very bottom of the file list.
-> Right after moving, XnView scrolls back to the very top.
If I understand you right, XnView should not scroll at all. Not sure whether this is feasible, since the file list needs a refresh after moving. Pierre will know...
LastZolex
Post by LastZolex »
LOL! You're probably right!
Thank you for your answer, Helmut!
absolutely correct, this is what I would expect to happen. It seems to work with version 1.61... almost always ;-)
probably it is just a small bug, maybe even a bug in the windows listcontrol itself?
I'll watch out for any new version, hoping this could be fixed! Anyway, it is the best imageviewer I ever used!
:) I'll stay tuned! :)
Last Zolex
