XnView 1.82.4 cannot open JBIG files
Fab
Post by Fab »
I download the version 1.82.4 to display JBIG2 pictures but it seems an unaivalable format.
On the web site JBIG is announce as available !
Can i load JBIG pictures with XnView ?
thanks for your answers
marsh
Post by marsh »
JBIG is listed as a supported format after extra plugins are installed.
Post by Guest »
Thanks you Marsh.
Can you please tell me where can i find these extra plugins ?
Anonymous wrote:Can you please tell me where can i find these extra plugins ?
Fabrice
Post by Fabrice »
Thanks.
It works perfectly with my JBIG2 images.
lelor63
JBIG crashes
Post by lelor63 »
I just installed the plugins.
XnView now recognises the JBIG (.jbg) file ... but crashes as soon as file is opened.
Any idea wht is the reason ... solution ?
Re: JBIG crashes
Post by Guest »
lelor63 wrote:Bonjour,
I found out that I can only open JBIG files from within the XnView explorer, once I have activated the visualisation of JBIG files - in explorer - from the 'options" menu ...
I cannot open a JBIG file either by double clicking, or by dragging the file to XnView, or if another program (such as my internet browser) calls for XnView : all this cause a crash. (under XP Pro)
