The images of Mars at the Malin site are really incredible. Many are very large gifs. Here is an example of one that XnView fails to view.
WARNING: This is an extremely large file (8.5 megabytes).
http://www.msss.com/moc_gallery/e19_r02 ... 101704.gif
XNView reports "GIF : Bad picture's size!"
My other image viewers have no problem with the image.
Error opening large gif: reports bad size
JohnFredC
ckit
I can confirm this bug or limitation.
XnView v1.70.4 - Doesn't open it in View Mode instead there is an error, in Browser Mode it launches IrfanView instead which is kinda funny.
IrfanView v3.91 - Works just fine
PhotoFiltre v6.0 - Works just fine, a little slow but I think the res needs lots of memory for it.
Serif PhotoPlus v6.0 - Works just fine, again a little delay in opening.
PCMag FileSnoop v1.1 - Lockups with 100% CPU usage
Mozilla Firefox 0.9.1 - Works just fine.
Update: converting the GIF (8.4Mb) to a PNG (6.9Mb) fixes the problem nicely. I also noticed that, that GIF has no thumbnail in Browser Mode in XnView.
Re: Error opening large gif: reports bad size
ok, a bugJohnFredC wrote:The images of Mars at the Malin site are really incredible. Many are very large gifs. Here is an example of one that XnView fails to view.
mols
Is this bug fixed? Cause i have the same problem with large EPS files:
Command
Message
Command
nconvert -quiet -truecolors -out jpeg -q 100 -dpi 300 -rmeta -o 'doutput.jpg' 'input new cmyk.eps' Code: Select all
Error: Portable Bitmap : Bad picture's size !-
Yes for gif, but could you post your eps file?mols wrote:Is this bug fixed? Cause i have the same problem with large EPS files:
mols
It's 98 MB big
I will send you a mail with ftp informations where you can download the file.
