When using selection, one can easily swap the orientation of the selection by pressing the Tab key (or choosing Edit > Selection - Swap width & height).
When reloading a user-defined selection size the selection is restored properly, but swapping width & height is not possible. I think swapping width & height should be always possible.
XnView 1.82.4
Orientation of User defined selection not changeable
Re: Orientation of User defined selection not changeable
Yes, righthelmut wrote:When using selection, one can easily swap the orientation of the selection by pressing the Tab key (or choosing Edit > Selection - Swap width & height).
XnView 1.82.4
