[newby] two "search" questions
hman
Post by hman »
[New xnview user, I tried looking around but didn't find the answers]
Is it possible searching for multiple kind of files at the same time ? Something like "*.jpg *.gif" should find gif and jpg files, I didn't find the syntax for that.
In the browser, after a Search->Browse, how can I return to the current directory ? I'm using "change into another directory"->"change back into the previous directory", is there some shortcut for getting back a normal directory view ?
Thanks
Re: [newby] two "search" questions
hman wrote: Is it possible searching for multiple kind of files at the same time ? Something like "*.jpg *.gif" should find gif and jpg files, I didn't find the syntax for that.
Currently it's not possible
In next release, you'll have a history button to go back to previous folder
hman
Post by hman »
Thank you!
gavp
Post by gavp »
Is this searching method available now?
hman
Post by hman »
Err... yes?
The first icon on the left above the "file list pane" should be a "Back" icon, with the default Skin of 1.95.3 a bluish/violet arrow to the left.
gavp
Post by gavp »
Thanks for the quick reply, I meant first part of the original post.
"Is it possible searching for multiple kind of files at the same time ? Something like "*.jpg *.gif" should find gif and jpg files, I didn't find the syntax for that. "
Dreamer
Post by Dreamer »
Not possible yet, AFAIK.
Dreamer
