Hi!
I love exif, but one thing I'm missing is a EXIF-Sidebar or something similar:
I take a lot of pictures with my digicam in different modes but with the same motive. The camera stores the details about the settings as EXIF in the pictures. If there was a sidebar (or always-on-top tool-window), which displays all the exif info, I would be able to compare the settings instantaneous and not having to click onto each pictures properties in XNView.
Thx
J.
Quick EXIF Viewer
Thank you for the quick reply!Troken wrote:If you change your thumbnail view to "Thumbnail & Labels" and then in options: Browser -> thumbnails -> thumbnail labels insert the EXIF-values of your choise. Then you will get you data in the browserwindow.
Since there are a lot of values, this is not very practical:
As you can see, there are no labels, but only a list of values.
greets
J.
Hm, yes, I can see the problem. To a certain point, you can cusomize how the show after your need. I can see that you've separated the data with a new line, but you can add the info in other ways.
Go to options -> browser -> thumbnails -> thumbnail label
Now, scroll down the left side options column and you'll find "custom 1", "custom 2", "custom 3" etc. In these, you can add more than one value to a label-line. You adjust the values by clicking the lower right "custom" button. Play around with it, maybe you'll get a somewhat acceptable result.
One custom field could have:
<Focal> - <Shutter> - <Flash>
As you can se, you can separate with a symbol, here a "-".
Jodokos
Thanks for your support!Troken wrote:Hm, yes, I can see the problem. To a certain point, you can cusomize how the show after your need. I can see that you've separated the data with a new line, but you can add the info in other ways.
Viewing files that way would be a solution (although I prefer an extra-sidebar or window), unfortunately I have no "custom" fields! I'm using version 1.82.4. How can I add them?
