What Kind of Tif is this? From Abbyy FineReader 8
brotondi
Post by brotondi »
Hi
I need to manipulate Scanns after FineReader saved them as a special Tif with 3 Frames. But no Program I know can read these Tifs...
Here an example: http://brotondi.pytalhost.com/0005.tif
Any Idea? (Dont lose too much time)
Thanks!
Bruno
Two in three…
:) Hello !
• Indeed XnView displays only the first frame, and doesn't open the others… :|
- The same with "The Gimp" … The best I could obtain is with "Imagine",
originally a free plugin for Total Commander (has a standalone version too…).
- I get this :
————Image
- No more, sorry… The third frame is black.
:mrgreen: KR
:arrow: brotondi & Clo
I can confirm Clo's observation. The 2nd frame is either corrupted or blank, but the 1st and 3rd seem to be OK.
Using XnView, you could extract those frames/pages into separate images:
  • Tools » Multipage file » Extract All Into...
You'll probably get a warning message (“TIFF : Bad data compression algorithm !”), but the extracted first and last frame should be just fine.
Method #2: Jump to a specific frame, copy it to the clipboard (Ctrl+C) and then paste it into an image editor.
  • View » Page » Last (Shift+End) / First (Shift+Home)
No page---
—> XnTriq
:) Hello !
• There is a snag with XnView : Despite the "Next page" button is available, it doesn't work !
- You don't get the next page !
- With "Extract all to…", I get only the two frames I show above, and like you say,
I get the error message (probably for the faulty missing frame)
:evil: Twisted format… :?
:mrgreen: KR
brotondi
Post by brotondi »
Thanks for your efforts. I think this is no regular Tiff-format
FineReader 8 (http://www.abbyy.com/finereader8/?param=45596) can import this Tiff (and all similar) without problem. From there it can be exportet (after some manual work for each single picture) to a regular jpg.
Unfortunately FineReader-Support was not able to tell me more about this format...
Bruno
The Gimp knows
—> brotondi
:) Hello !
- You are welcome !
- When trying to open the pic with "The Gimp", I got a very detailled error message
(not faulty pic, but not supported) with the exact type of file…
————— Image
:mrgreen: KR
brotondi
Post by brotondi »
Thanks Clo for your Help!
I'm now searching a Program which is able to convert Tiff with PlanarConfiguration=2 ... but this format is not well known... http://groups.google.ch/group/comp.grap ... 7d8671358/
we will see if I'm lucky :?
Bruno
