B1: error with 'Open' non-displayable file when Hex is ON
Olivier_G
Post by Olivier_G »
With Options>Read/Write: 'Show hexadecimal for non-displayable files' ON, when you open a non-displayable file via Menu>File>Open, you get an error message "Format of the file <> could not be determined".
XnView should directly show the Hex mode without any error message.
Olivier
Old times
:) Hello !
• This was the usual behaviour in very old versions, IIRC…
- So, I support !
:mrgreen: KR
laude
marsh
Post by marsh »
I agree.
ckit
Post by ckit »
I don't get an error message with Beta 2 but the files fail to appear in hex mode in XnView.
ckit wrote:I don't get an error message with Beta 2 but the files fail to appear in hex mode in XnView.
Strange, if i use menu File/open a unknown file, i have the hexa view
Olivier_G
Post by Olivier_G »
Confirmed for me too... :?
Olivier
marsh
Post by marsh »
It works for me. Have you changed your 'Open With' and 'Items Displayed' settings since first reporting this?
Olivier_G
Post by Olivier_G »
marsh wrote:Have you changed your 'Open With' and 'Items Displayed' settings since first reporting this?
You nailed it! I just set Options>Keyboard/Mouse>"Open action" for 'All other files' to 'XnView' and the unknown file was opened in hexaview... :D
But...
...XnView should open a file in XnView if I specifically use Menu>Open (rather than using Keyboard/Mouse on Filelist) and bypass all those "Open action" settings. This is the way it works for recognized files, right?
Olivier
marsh
Post by marsh »
But...
Yes, I think Menu>File>Open bypasses all those settings (with some version or another).
Olivier_G
Post by Olivier_G »
Olivier_G wrote:But...
Works fine according to this situation. Thank you Pierre! -> Closed.
Olivier
