When moving one or several files to a folder with files with the same name in it, XnView displays the dialog "Replace existing file". This dialog offers to replace the existing file, rename the moved/copied files, to skip, or to cancel.
For renaming, there is an edittext for changing the existing filename in the dialog. It would be convenient if the user could define a default suffix in the options which is added to the suggested file name for renaming. That way, the user could simply press "Rename" and would be done.
Note: This suggestion is the translated wish from German user Gunnar.
Auto suggestion for renaming
- Forum Librarian
You betcha!helmut wrote:Would other people find this useful?
Re: Auto suggestion for renaming
* bump *
I've received another mail of Gunnar (a bit enerving). Some reaction/answer/estimate from you (Pierre) would be good.
Ok i'll add an option for that... (not for 1.97.1)helmut wrote: I've received another mail of Gunnar (a bit enerving). Some reaction/answer/estimate from you (Pierre) would be good.
