Icon problem "The image contain multiple pages..."
otreus
Post by otreus »
Hi:)
I have this problem (with other prog i haven't it), when i click on some icons i see the msg "The image contain multiple pages..." and the icons are in black and white :(
What i must do for resolve this problem? Many thank's :D
Windows icons are multi-page files, which means they can contain more than one image. XnView lets you browse these images with the Previous page/Next page command.
For further information on how to navigate through multi-page/multi-frame files go to Topic #7791.
Offsite References
Old issues
—> otreus
:) Hello ! Welcome aboard !
…and the icons are in black and white …
• I guess you mean that the background is always black, don't you ?
• This occurs for icons having a transparent BG and a workaround has been implemented
in the new 1.90.2 version, you might give it a try…
- However, all *.ico files will be shown as 32-BPP colour-depth in the status-bar, info-texts etc.,
that indeed is not right, it's a subsidiary issue not fixed yet (and which seems hard to fix up…).
- There is a pretty bunch of threads about this, you might use the Search:wink:
:mrgreen: Kind regards,
otreus
Post by otreus »
thank's for the help and sorry for my terrible english.
There is an error in my post, the file aren't .ico files (it contain icons) but .png file
I have click the special buttons but i see the same icons but small and the icons are always in black and white
Is hard for me translate your help, i want only know why i can's see these png and what i must do for see it.
Can u explaine me exactly (and in the easy mode) what i must do? :? :wink:
If is necessary i can send you the image
otreus wrote:thank's for the help and sorry for my terrible english.
Could you send me a sample?
otreus wrote:There is an error in my post, the file aren't .ico files (it contain icons) but .png file
It's a known issue: XnView doesn't display .PNG with transparency correctly.
otreus wrote:Is hard for me translate your help, i want only know why i can's see these png and what i must do for see it.
  1. Go to Tools » Options... » Gerneral » Read/Write » Read » PNG » Parameters and de-activate both Compose image with transparency and Compose image with alpha (32bits).
  2. Go to Tools » Options... » View » View and activate the checkbox for Use transparent index (<=8bits) or alpha channel.
Free online translation services:
otreus wrote:If is necessary i can send you the image
If you would like to post an image on this forum, you can upload it to a free hosting service like ImageShack or Photobucket etc.
Use this address to send it directly to Pierre via e-mail.
otreus
Post by otreus »
thank' s for help but i haven't luck :(
I have send the icons to Pierre
Thank's for all :D
