Don't know if this has been metioned before. .tif-Images created with Paint.NET (OpenSource at http://www.getpaint.net/) can not be opened with XnView. Even the shell extension fails to load it.
1.90.3 on german WinXP SP2
Display of .tif-Images slow
Re: 1.90.3 on german WinXP SP2 - Display of .tif-Images slow
Could you send me a sample, please?Surfi wrote:Don't know if this has been metioned before. .tif-Images created with Paint.NET (OpenSource at http://www.getpaint.net/) can not be opened with XnView. Even the shell extension fails to load it.
nerbrume
I'm not sure it's related, but I have the same problem with a tif (origin unknown). Here it is :
http://nerbrume.free.fr/images/Plan.tif
(opens fine in windows viewer, not in XnView).
Btw, since I'm here, thanks a lot for XnView, Pierre !
Sure, it's just a small image.
You can load it here:
http://rapidshare.com/files/23731975/_1 ... t.tif.html
XnView *really* has problems with the TIF images provided above. What I experienced:
- Surfi's image does not open in XnView (XnView will allocate several 100 MBs of memory and hard disk will swap).
- And nerbrume's TIF appears in preview but does not open.
Good to read that this will be fixed (hopefully soon).xnview wrote:Ok, i'll fix it
