Reducing file size of many files
redshoot
Post by redshoot »
Hi
I am using XnView to convert BMPs to JPGs with no problems
Now I need to reduce the file sizes of around 150 JPGs by about half
I cant seem to do it
Where do you enter the script to do this ?
Any help appreciated
I am a bit of a novice
many thanks
Stuart
<Moderator's note: This topic has been moved from group 'NConvert'>
Re: Reducing file sizes
redshoot wrote:I am using XnView to convert BMPs to JPGs with no problems
You can use -q for jpeg quality
redshoot
Files size reduction
Post by redshoot »
Thanks Pierre
I am using the program XNview,
where do you actually enter the -q ?
stuart
Re: Files size reduction
redshoot wrote: I am using the program XNview,
You are in the NConvert newsgroup ;-) In XnView, options/Write/jpeg
redshoot wrote: ...
For applying an operation on many files, there is two ways:
a- You can use NConvert
b - You can use the Batch conversion of XnView
For using NConvert (a), you have to be familiar with command shell and scripting. There's more info in the newsgroup 'NConvert'.
Using XnView for Batch conversion (b) is quite simple. In the XnView browser select several files and then choose menu 'Tools > Convert...'. In the dialog 'Multi conversion' you specify file type and output directory to save and if you want, you can also apply one or several transformation. This can be effects and filters for example. In the help document you will find more infos on the usage of XnView, multi conversion is not described in detail, yet.
Important note:
Before converting many files, you should start with a small number and do some testing.
And you should be aware that saving files in JPG format will loose some of the original quality. And if you save a JPG file, again, you will again loose quality. See also the discussions in
- Details lost when Resizing and Saving Photos
- Smaller image has same file size
- Resizing image results in larger file
