When I go to use the 'Copy to Folder' function to copy some selected images to another folder and that folder already contains images of the same names, I am presented with a nice dialog that shows thumbnail pictures that compares the original file with the new file. I like this... thanks!
But since I already know that I am replacing the original images with the new images (because I just image-processed or re-rendered them), I want to replace them without seeing the dialog again. I want a checkbox that says 'Apply to all duplicates' or whatever.
Is there currently a way to do this or is this a future request?
Thanks!
Replace Multiple Files Request
Mike Truly
Sincerely,
Mike Truly
Truly Media
http://www.trulymedia.com
Mike Truly
Truly Media
oops66
Re: Replace Multiple Files Request
Have a look here:Mike Truly wrote: But since I already know that I am replacing the original images with the new images (because I just image-processed or re-rendered them), I want to replace them without seeing the dialog again. I want a checkbox that says 'Apply to all duplicates' or whatever.
Thanks!
http://newsgroup.xnview.com/viewtopic.php?t=13622
Mike Truly
Thank you for that link.
So it looks like others would like to have a checkbox in the dialog giving the option to either prompt for each file or to overwrite all files. I vote for this too.
Thanks!
Thanks!
Sincerely,
Mike Truly
Truly Media
Mike Truly
Truly Media
