Dragging a pic to a category does not update iptc
lsolesen
Post by lsolesen »
It seems that the iptc info is not updated if you drag an image to one of the predefined cateogories.
Lars Olesen
Re: Dragging a pic to a category does not update iptc
lsolesen wrote:It seems that the iptc info is not updated if you drag an image to one of the predefined cateogories.
Categories are not iptc, it's a DB
lsolesen
Post by lsolesen »
But shouldnt they somehow be related. The very strong point about xnview is that it utilises iptc and meta data in the pictures?
lsolesen wrote:But shouldnt they somehow be related. The very strong point about xnview is that it utilises iptc and meta data in the pictures?
There is another topic about that, i'll add an option to synchronise categories and IPTC
lsolesen
Post by lsolesen »
I think it should be standard, not just an option. It is expected behaviour I think.
lsolesen wrote:I think it should be standard, not just an option. It is expected behaviour I think.
Not for all users :-)
lsolesen
Post by lsolesen »
No, but what would be most common to assume. That the data is saved - as all the other data - in the picture, or that, that particular piece of data is not saved. I think that most people would expect it to be saved, and the people who does not want it saved can get an option, where they can turn the syncro off. IMHO.
oops66
Post by oops66 »
No, not for all users and not for me!
I do not want to save my taggeds items into the database by default each times.
category.db is also usefull for some temporaries uses, especialy for tags.
lsolesen
Post by lsolesen »
IMHO, I think a program should be easy to use for a beginner. I think the smartest default will be to save it. The fact that you have an opinion whether to save in the file or in a db, says to me, that you know more than most users. Therefore, you should off course have the option to do as you please, but I still think that saving in the file will be the smartest use case for beginner users.
zips
IPTC and Categories hand in hand ?
Post by zips »
xnview wrote:i'll add an option to synchronise categories and IPTC
Oh yes please!
z.
