Wouldn't it be nice if, while you were browsing through photographs that you could click the rotate-clockwise button and then browse on to the next photo *without* having to click on that nagging "do you really want to save changes" dialogue box. There's no way to turn it off.
Thanks!
Turn off "save changes" confirmation.
Brother Gabriel-Marie
- Forum Librarian
oops66
Re: Turn off "save changes" confirmation.
Hello,Brother Gabriel-Marie wrote:Wouldn't it be nice if, while you were browsing through photographs that you could click the rotate-clockwise button and then browse on to the next photo *without* having to click on that nagging "do you really want to save changes" dialogue box. There's no way to turn it off.
Thanks!
If some images *.jpg are in a wrong orientation, you can do :
1-) if your camera is compatible : in options\general\operations tag\rotate images based on EXIF orientation.
2-) if not compatible,the best way (& easier) for me is to rotate "lossless transformations" the file and save it in the right orientation.
