Print "Single - DPI" - how does it work?
Peter2
Post by Peter2 »
I don't understand how this command works. I have Scans (TIF) with 400 DPI and Screenshots (PNG) with 96 DPI. I have no idea what happens why ...
Peter
Re: Print "Single - DPI" - how does it works?
"Single - DPI" use the dpi of picture and the dpi of the printer
Peter2
Post by Peter2 »
xnview wrote:"Single - DPI" use the dpi of picture and the dpi of the printer
Please give an example ..
Peter
If you have:
picture 2000x2000 px, 300 dpi
So the printed rectangle will have a size of 6.7x6.7 inches
Peter2
Post by Peter2 »
If the file has a resolution, e.g. 2000 pixel total with 400 DPI, and the printer has 600 DPI - will it be. ...
2000/400 = 5 inch?
or
2000/600= 3,33 inch?
Peter
Peter2 wrote:If the file has a resolution, i.e. 2000 pixel total with 400 DPI, and the printer has 600 DPI - will it be.
2000/400 = 5 inch?
or
The dpi of printer will only be used to resize picture, but the printed area will be the same (5 inches)
Peter2
Post by Peter2 »
Thanks - I think I got it.
Peter
Peter2
Post by Peter2 »
Me again ...
so this a the same result as "Scale 1 = 1"?
Peter
Peter2 wrote: so this a the same result as "Scale 1 = 1"?
No, dpi is not used
