If using function fit width by keybord (Numpad 1) the picture shold be centered. By using Numpad 1 from fit windows or zoom out views, picture appears in top position, from zoom in views picture appears in bottom position. This happens in both fullscreen or windows view. Function Fit width by menue works correctly, picture appears centered.
Werner
'Fit width' by Numpad1 - picture not centered
cumulus31
- Forum Librarian
Werner, please check your settings for Auto Image Size & Reset X/Y (Tools » Options... » View » View) and Lock Zoom (View menu in View mode).
- Position sur les images en plein écran
- Configurable "lock position" feature
- Always show the top of pics / Edit description in view mode
- X/Y Confusion
- Fit Window to Image and Reset X/Y incompatible?
- "Reset X/Y" setting in fullscreen
- Anyway to view an image starting from the top, not middle?
- Problem with Lock Zoom
- Reset X/Y doesn't work when "Lock Zoom" is on
- Top of image when changing...
- B1: Image position inconsistency
- Reset X/Y -> Dependency of Lock Zoom
