I tried printing a large tiff graphic, (29 inches wide by 24 inches high) to a PDF file. The images mirrored. I tried printing to the same PDF file with two other graphic programs and they worked fine. I could find no reason for this in Xnview, could you please check it, as I would prefer using Xnview for most all of my graphic enhancements.
Thank you
John D. Taylor III
printing to PDF mirrors tiff images
- Forum Librarian
According to the changelog this problem was fixed in v1.91.6.
Johndt3, are you using the latest version of XnView (1.95.4 of 19/Nov/2008)?
XnTriq ([url=http://newsgroup.xnview.com/viewtopic.php?p=53513#53513]Print-custom problem[/url]) wrote:cataratta wrote:There is also another strange issue :
for some tiff files the preview on print panel is right then the print on paper is flipped vertical and orizontal!!!Crazy.
I must flip the image befor the print for have correct on paper.
Regards
- TIFF images with TIFFTAG_ORIENTATION not displayed correctly
- print fax cover (MIRROR)
- Impression Inversée d'images TIFF
xnview ([url=http://newsgroup.xnview.com/viewtopic.php?t=13494]Prints Inverted[/url]) wrote:It's a known bug, will be fixed in 1.91.5arovelstad wrote:Whenever I print a file that is fine in the viewer it comes out vertically flipped, i.e., mirrored about a horizontal line. Other users here have this problem with only some printers. For me it's all of the printers I have tried. If I flip the view vertically, it prints fine. Is there a setting somewhere I need to reverse?
