Margins & Borders
dreamlike
Margins & Borders
Post by dreamlike »
Hi everybody,
I'm a new satisfied XnView user and I'd like to give a suggestion to improve the features of this viewer.
When I publish my photos I create around the image both a border and a margin. I've checked your canvas resize function but I think it can be improved as well. First of all I suggest to insert a dialogue where you can directly insert the numbers of pixels for each margin. Further you could have a new sub menu where you can specify the number and the colour of the border around the image. Of course, both these features have to be also in batch processing.
Hope to give you a good suggestion
bye
Alberto
film director
www.albertogelpi.com
dreamlike
Post by dreamlike »
thanks for your quick reply .. sometimes I'm quite blind!!!! sorry!
Anyway, hope you'll add a border option in canvas resize menu because in order to achieve the result of having both a some pixels border and a margin (to create a frame) you need to follow two steps (the first to create the border and the second to create margins) ... and it's not so friendly, in particular in batch processing!
Anyway, I'll definitely use your amazing viewer!!!
Congrats
film director
FYI: Pierre Image is the developer of XnView. I'm just a satisfied user like you. ;-)
