can you please implement the posibility to sort the pictures in the Viewer free by custom via dragging and droping the thumbnails? The custom sort order should be able to use for example renaming or slide shows. The new order should be saved for each folder.
Thanks
Custom Sort Order
- Forum Librarian
XnTriq ([url=http://newsgroup.xnview.com/viewtopic.php?p=54170#54170]to move the mini pictures[/url]) wrote:
- Sorting Thumbnails for batch rename
- Rearrange/Remember Thumbnail Positions [Enhancement]
- Batch Rename: Ordering files per Drag&Drop
- Request for Thumbnails in Batch Rename and Slide Show
- Tri par drag&drop dans la fenêtre vignettes
- Drag-and-drop thumbnail renaming
- Create Web Page and Contact Sheet
- moving files within folder
- Arrange Categories
Dreamer
Some features are hard, or impossible to implement in the current version, therefore Pierre has created (or rather he is creating) XnView MP. More info about this project:Karl02 wrote:This feature has been requested at least 11 times in the last five years, so I really wonder why Pierre doesn't add it.
What exactly is XnView MP?
Dreamer
Karl02
I know XnView MP and like the approach, but unfortunately it's in a very early state.
Since XnView is described as "a free software to view, organise, convert graphics files" (see http://www.xnview.com/), it should be possible to sort images with it, since sorting is a main aspect of organising. So this feature should be implemented as soon as possible if it's not too difficult, otherwise the work would be better invested in XnView MP, and in XnView there should mainly be fixed bugs.
-- Karl
Dreamer
There is a possibility to sort the images using up and down buttons in Batch rename and Slide show, so what about such a feature, perhaps as tab (already requested), for more features, e.g. Batch processing, but with another feature, show thumbnails view, something like thumbnails and details view, with drag & drop, or at least those buttons?
Dreamer
