Converting multipage PDF files into images?
Hasan
Post by Hasan »
Hi :)
Its me again :D. Is there any method / command / plugin etc., for converting pages of multipage PDF files into images (i.e., .GIF, .PNG, .JPG etc.,). For instance, a PDF file "book.pdf" has 10 pages, and someones wants to convert these 10 pages into images. Can xnview do that? Like reading the PDF file and saving its every page as a separate image?
Apparently, XnView can only convert 1st page of a PDF file. Any suggestions?
Hasan Ali
Re: converting pages of multipage PDF files into images?
Hasan wrote:Its me again :D. Is there any method / command / plugin etc., for converting pages of multipage PDF files into images (i.e., .GIF, .PNG, .JPG etc.,). For instance, a PDF file "book.pdf" has 10 pages, and someones wants to convert these 10 pages into images. Can xnview do that ? like reading the PDF file and saving its every page as a separate image?
Apparently, xnview can only convert 1st page of a PDF file. Any suggestions ?
Use View/Page/Extract all into...
Hasan
Post by Hasan »
Hi!!
Sorry for a late response. I could not find this command combo. Will you please explaint it a bit ? I have Xnview 1.74 and I did not find "page" options in any "view menu" :(. Thanks
Hasan
Dreamer
Post by Dreamer »
Hasan wrote:
xnview wrote:Use View/Page/Extract all into...
Hi!!
Hasan
I can see that option, but I can't use it, some plugin is needed probably, are you using some?
You can find that option in Viewer - not Browser - Menu - View > Page > Extract all into...
Hasan
Post by Hasan »
Hi!!!
Dreamer wrote:I can see that option, but I can't use it, some plugin is needed probably, are you using some?
So you can see that option, which version you are using ? I'm using 1.7.4 and there is no option of "page" in "view" menu.
I'm not using any plugin, are you ??? (as you can see that option)
Hasan
Blurred, but prersent !
>> Hasan
:) Hello !
“Dreamer” is right, that entry exists always in the View menu of the main browser window .
- But it can be blurred (greyed) when not available, following the file-type you are displaying into…
:mrgreen: K R
Dreamer
Post by Dreamer »
Hasan wrote:Hi!!!
Hasan
I'm using 1.74 too.
BTW This useful feature is hidden, users expect such features under File > Export...
Dreamer wrote:BTW This useful feature is hidden, users expect such features under File > Export...
I agree. 'View' menu is for viewing, not other functionality.
I suggest to change the existing menu item "Tools > Create multipage" to "Tools > Multipage >" with a submenu:
Create...
Extract all
Extract all into...
Dreamer
Post by Dreamer »
helmut wrote:I suggest to change the existing menu item "Tools > Create multipage" to "Tools > Multipage >" with a submenu: ...
Your solution make sense, but I think users expect such options under File > Export... it's like that in many programs I know and also "Save" and "Save As" is there...
Hasan
not present at all...
Post by Hasan »
Clo wrote:>> Hasan
:) Hello !
:mrgreen: K R
Dreamer wrote:I'm using 1.74 too.
I'm very much :shock: to see your interface of 1.74 version
Cos my xnview 1.74 version is slightly different as you can see the available menus :(
Hasan
Dreamer
Post by Dreamer »
Again, you must use View mode, not Browser mode - to do it use the 1st toolbar "eye" button - Open or mouse double-click on pdf file.
Hasan
Post by Hasan »
Hi :)
thanks Dreamer, the problem is solved.
Hasan
Dreamer wrote:Again, you must use View mode, not Browser mode - to do it use the 1st toolbar "eye" button - Open or mouse double-click on pdf file.
Hasan
Post by Hasan »
Hi again :D
forgot something. by default, it "extracts" pages as .bmp. Can I extract in any another more compressed format ? like .gif or .png or .jpg ?
Hasan
Hasan wrote:Hi :)
Hasan
Dreamer
Post by Dreamer »
Hasan wrote:Hi again :D
Hasan
Probably it's not possible yet.
Check another similar request Extract multipage TIFF to other format than BMP (and add your request there maybe...)
