Plugins not recognized after unzipping in Plugins director
reckoner
Post by reckoner »
I am trying to install the slideshow video plug-in:
http://www.xnview.com/download/addons/video.zip
I have read through the forum and unzipped the files in the
c:\XnView-win\XnView\Plugins
Directory, but when I restart xnview and go to Info->Plug-Ins Information, I don't see the new DLL's that I have just unzipped.
Here are the contents of the above directory:
libmcl-5.3.1b4.dll
libdsw-1.0.7.dll
Xjp2.dll
slide.exe
mpeg.dll
libwmv-1.0.4.dll
libogg-2.0.2.dll
libmpg-2.0.5.dll
What am I missing?
Thanks again
Re: Plugins not recognized after unzipping in Plugins director
Not in Plugins but Addon folder
reckoner
Post by reckoner »
xnview wrote:Not in Plugins but Addon folder
The following are the contents of the Addon folder:
Xmp.xnp
PhotoMasque.xnp
PhotoMasque.lng
PhotoMasque.dat
Paint.xnp
Paint.lng
NeroCD.xnp
NeroCD.lng
FTP.xnp
FTP.lng
Masks
libwmv-1.0.4.dll
libogg-2.0.2.dll
libmpg-2.0.5.dll
libmcl-5.3.1b4.dll
libdsw-1.0.7.dll
I still see nothing when I check for these in the Info menu.
Thanks
Info/Plugins doesn't list Addon plugins
reckoner
Post by reckoner »
Thanks for your reply.
There is an Info/Plugins/Addons menu Which refers to the Xnvew\Addon directory. However, none of the above mentioned files are listed there. Is there some way I can verify that it is actually obtaining access to these dll's. I'm trying to create an mpg movie from a slideshow, but I can't seem to get it to work.
Little help?
yes right. Start slideshow dialog, and you should have 'create video' button
xnview wrote:Info/Plugins doesn't list Addon plugins
PlugIns in PlugIn directory makes sense. Plugins in AddOn directory is strange. And a dialog which displays the PlugIns in the AddOn directory, only, is even stranger. Couldn't this be cleaned up to avoid further problems, misunderstandings and headaches?
Suggestions for PlugIns and Addons:
1 - All PlugIns should be in "PlugIns" folder
2 - All AddOns should be in AddOns folder
3 - "AddOn" folder should be renamed to "AddOns" (plural, like "PlugIns")
4 - There should be a way to display PlugIns info and AddOns info for checking correct installation.
:arrow: helmut
• Hi !
• What about all additional stuff in a single sub-folder named for instance : “Plug-ins_Add-ons” ?
A common listing is indeed desirable, but unfortunately there are DLLs and EXEs in both types…
- A workaround should be that Pierre'ld add a prefix (i.e. A_) to all current add-ons,
then they could be spotted easily in such a common listing… Image
:mrgreen: G.
helmut wrote:PlugIns in PlugIn directory makes sense. Plugins in AddOn directory is strange.
Plugins folder is only for I/O format plugins (used by Nconvert & GFLSDK), Addon is for XnView plugins
XnTriq ([url=http://newsgroup.xnview.com/viewtopic.php?p=45565#p45565]Viewing archives does not work properly[/url]) wrote:
helmut wrote:As written above I haven't dealt with this matter before. But I think installation and dependencies inbetween AddOns is quite a hurdle. :-|
Some suggestions:
- Download packages with subfolder path included
All Plugins and AddOns should be zipped with relative folder ("Plugin" / "AddOn") included. Then, the user simply unpacks the ZIP archive in the program folder of XnView and everything is alright.
guest - murthymsr ([url=http://newsgroup.xnview.com/viewtopic.php?t=11861]XnView plugins and third party plugins[/url]) wrote:There are about 6 plugins to be placed in the addon directory. And there are more than 30 plugins provided by third party developers. More may be added with time.
For one like me, who loves experimenting with varous available facilities, unzipping each of those plugins into a single directory (addon or plugins) may create problems particularly while trying to remove some of them.
So, I request Pierre and all third party plugins developers to install (unzip) into a different subfolder corresponding with the particular plugin.
for example, neroCD plugin may be placed in the folder .../addons/neroCD and so on.
Request Pierre and the developers of third party plugins may consider the possibility.
Installing plug-ins & add-ons into subdirectories could also help to eliminate the guesswork when tracing down bugs:
