RC2: Use different pos./size for browser & view
Dreamer
Post by Dreamer »
"Use different position/size for browser & view" doesn't work in RC2.
Also with default settings.
- close xnview
- rename xnview.ini file
- start xnview.exe
- F12 - enable "Use different position/size for browser & view"
- click once to any image
- go to viewer with the 1st toolbar button "Open" and back with "Enter"
- restart xnview (start xnview.exe)
= position and size is not changed - same as browser
Re: RC2 BUG: "Use different pos./size4browser&view&
Dreamer wrote:"Use different position/size for browser & view" doesn't work in RC2.
- close xnview
- start xnview.exe
Fixed
Dreamer
Post by Dreamer »
xnview wrote:Fixed
Not fixed in RC3.
marsh
Post by marsh »
May 28: I still cannot recreate problem. I removed all traces of Xnview, selected the option, restarted, and both viewer and browser dimensions were remembered (seperately). Win2k.
Dreamer
Post by Dreamer »
Viewer is even centred on screen at startup, then Browser has correct size & pos. but if I press Enter to go to Viewer, size & pos. is the same as Browser.
marsh
Post by marsh »
I understand "Use different position/size for browser & view" to be "Remember browser
and viewer dimensions seperately". These terms do not have identical meanings. The
first phrase implies that different positions are forced, while the second does not.
"Remember browser and viewer dimensions seperately" works for me.
Dreamer
Post by Dreamer »
Am I the only one??
Dreamer wrote:Am I the only one??
I can't reproduce the problem. If i start browser, open one picture.
Resize or move it, then go bakc with return. Browser gets original size. I open new picture, and size of view is changed to view size.
Dreamer
Post by Dreamer »
Very strange :|
Dreamer
Post by Dreamer »
No :)
Note: Moved from another thread. (Reason - too many topics for the same problem :wink: )
Post by Danny
(RC4) Remember last window position/size
If you start the program directly this doesn't work. It will always revert to the same standard setting. It only works, if you open up a picture directly for example.
This has been posted by a guest in the RC3 thread already but has not gotten any attention yet. That's why i made this thread.
Post by marsh
Yes, the problem now is that both views default to the last view closed when program exits. Dimensions are only remembered seperately on a per session (temporary) basis.
http://newsgroup.xnview.com/viewtopic.php?t=2140
http://newsgroup.xnview.com/viewtopic.php?t=1968
Dreamer
Post by Dreamer »
In RC3 has been saved always the browser window only, now in RC4 is saved always the viewer window only, for me.
Dreamer wrote:In RC3 has been saved always the browser window only, now in RC4 is saved always the viewer window only, for me.
Yes, i fix it :-(
Dreamer
Post by Dreamer »
Not fixed in RC5 :( (tested with old .ini and default settings)
Moved back to "New/Open"
Danny
Post by Danny »
Note: Edited / Moved
RC5: Use different position/size for browser & viewer
Options -> General
Doesn't work as expected. Once activated the viewer always uses the browser's setting, if you open the viewer by doubleclicking on a file in Windows Explorer.
Dreamer
Post by Dreamer »
Note: Moved
ckv wrote:probably side efect when fixin these bugs (check the later 'size / pos bug when using send to menu' posts)
http://newsgroup.xnview.com/viewtopic.php?t=2122
Locked
