Color codes
Papyrus
Color codes
Post by Papyrus »
How can i change the descrption for the color codes and the "ranking code"? -- Können die einzelnen Zuordnungen für "Bewertung" und "Farbkennzeichnung" geändert werden?
Thanks
Steve
ckv
Re: Color codes
Post by ckv »
Papyrus wrote:How can i change the descrption for the color codes and the "ranking code"? -- Können die einzelnen Zuordnungen für "Bewertung" und "Farbkennzeichnung" geändert werden?
Thanks
Steve
You can can change the default color and rating descriptions by manually setting the ColorLabel-# and RatingLabel-# values in you XnView configuration.
Add these values in your XnView.ini or registry key under the Browser section. See this wiki page for more info.
ColorLabel-0 = Important
ColorLabel-1 = Work
ColorLabel-2 = Personal
ColorLabel-3 = To do
ColorLabel-4 = Later
RatingLabel-0 = Bad
RatingLabel-1 = Below average
RatingLabel-2 = Average
RatingLabel-3 = Good
RatingLabel-4 = Excellent
Re: Color codes
helmut ([url=http://newsgroup.xnview.com/viewtopic.php?p=6230#p6230]Info about XnView's settings (store & load)[/url]) wrote:Location of .ini files
The setting "Save options" (see above) also controls the location of the .ini file:
  • * User - User's Application directory
    * Program - Program directory of XnView
    * Windows - Windows directory
The full path of the .ini files is displayed in the About dialog (menu "Info > About...").
ckv ([url=http://newsgroup.xnview.com/viewtopic.php?p=73420&hilit=ColorLabel+RatingLabel#p73420]UI-less Settings[/url]) wrote:ColorLabel-# (0-4):
Overrides the default color category names.
  • 0. Important
    1. Work
    2. Personal
    3. To do
    4. Later
Value: String
See also RatingLabel-# setting
RatingLabel-# (0-4):
Overrides the default rating category names.
  • 0. Bad
    1. Below average
    2. Average
    3. Good
    4. Excellent
Value: String
See also ColorLabel-# setting
Too little, 2L8 :P
Papyrus
Re: Color codes
Post by Papyrus »
Thank you very much for this explanation.
But:
1. I'm using Windows 7, 64bit / XnView 1.98.2 in German Language
2. in the xnview.ini i can't find the "ColorLabels" and the "RatingLabels" (in all sections)
3. when i change the "Save options" to the "Registry" --> Restart --> there also no "ColorLabels"/RatingLabels" to find in the "Registry"
Do you have ideas?
Many thanks for the support!
Steve / Switzerland
Re: Color codes
  1. In XnView, go to Tools » Options... » System integration » Integration » Save options and make sure that as INI in folder is activated.
  2. Leave the Options dialog by clicking OK to save this setting.
  3. Go to Info » About..., select the path behind INI file location and copy it to the clipboard.
  4. Quit XnView.
  5. Start Notepad.
  6. In Notepad, go to File » Open..., paste the path to xnview.ini from the clipboard into the File name field and click on Open.
  7. Locate the [Browser] line in xnview.ini.
  8. Copy the following text...
    ColorLabel-0=Important
    ColorLabel-1=Work
    ColorLabel-2=Personal
    ColorLabel-3=To do
    ColorLabel-4=Later
    RatingLabel-0=Bad
    RatingLabel-1=Below average
    RatingLabel-2=Average
    RatingLabel-3=Good
    RatingLabel-4=Excellent
    ... and paste it below the [Browser] line.
  9. Customize the text after the equal signs to your liking.
  10. Save xnview.ini.
  11. Restart XnView.
