"File Association" - no chance to cancel
Peter2
Post by Peter2 »
Maybe it is already discussed, but using the buttons for files associations (Menu Options) set the associations immediately. The "Cancel button" does not cancel these settings - and this can cause bad surprises :?
Any ideas?
Peter
Re: "File Association" - no chance to cancel
Right, but you have 'restore'
Peter2
Post by Peter2 »
xnview wrote:Right, but you have 'restore'
Where? What?
Peter
you have in options/associations>Restore all
Peter2
Post by Peter2 »
xnview wrote:you have in options/associations>Restore all
Mmmmmmh ... :?
In German translation it is translated with "None" which seem to be correct. IMHO there is no "Restoring", but there is an "unselecting of all". This is not a solution for a user who is playing around, pressing any button in the options and thinks "No problem, I will not press OK".
Or is it really a "restoring"? Then the German translation and the behaviour of the selection is confusing ....
Peter
Peter2
Post by Peter2 »
Peter2 wrote:Mmmmmmh ... :?
Peter
Any comments?
Peter
'Restore all' removed xnview association, and try to use previous association (if possible)
Peter2
Post by Peter2 »
xnview wrote:'Restore all' removed xnview association, and try to use previous association (if possible)
Is this the current feature or an idea for improvement?
Peter
Peter2 wrote:Is this the current feature or an idea for improvement?
This backup/restore is already implemented.
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\.wbz]
@="XnView.Image"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\.wbz\XnView.bak]
@="wbzfile"
budz45
Post by budz45 »
IMO it should be better named to "Remove all associations" which would do the same restore :D - much more clearer to me as user, at least in English anyway. :wink:
