"Use transparent index" option missing
bagheerah
Post by bagheerah »
I need thumbnails in browser not to use the alpha channel. I turn on: "ignore Alpha channel" in ""options>General>Operations"" but it only fixes the viewer window.
Also I've read that there's an "use transparent index" option under ""options>View>View"" but it DOES NOT appear in my options window though I am using the 1.98.2 version.
Any idea where this option can be?
Any idea how to turn the thumbnails transparency off?
possibly usefull information:
1- I have recently updated DirectX and had a very old Xnview version installed, then icons started showing transparency.
2- Next I updated to Xnview 1.98.2 (without previously uninstalling older version) but still cannot hide thumbnails transparency.
(I've restarted my computer after both operations)
Thank you in advance.
Re: "Use transparent index" option missing
bagheerah wrote:I need thumbnails in browser not to use the alpha channel. I turn on: "ignore Alpha channel" in ""options>General>Operations"" but it only fixes the viewer window.
View » Rebuild thumbnails
bagheerah wrote:Also I've read that there's an "use transparent index" option under ""options>View>View"" but it DOES NOT appear in my options window though I am using the 1.98.2 version.
View » Use transparent index (<= 8bits)
bagheerah
Post by bagheerah »
Thank you but in my XNview under the "view" menu there's not that option: "use transparent index"
the list of items under the menu "view" is:
-view as>
-sort by>
-filter by>
-collumns>
-Layout>
-Thumbnails size>
-Preview>
-stop animation
-Tags>
-rating and color labels>
-set categories...
-show files in subfolder
-Rebuild thumbnails
-Refresh Ctrl+R
-Stop Esc
-Tabs
-Toolbars
-Small Toolbar
-Tree pane>
-Preview pane>
-Status bar
And not a single item else.
And rebuilding thumbnails does not help removing the transparency.
bagheerah wrote:Thank you but in my XNview under the "view" menu there's not that option: "use transparent index"
XnView has two modes: Browser and Viewer.
The Use transparent index (<= 8bits) setting can be found in the View menu in Viewer mode.
bagheerah wrote:And rebuilding thumbnails does not help removing the transparency.
Ignore alpha channel seems to apply to Viewer mode only :?
Have you experimented with the parameters in Tools » Options... » General » Read/Write » Read » PNG?
Related topics:
bagheerah
Post by bagheerah »
Solved, the only problem I had was to find an image that would allow to unfreeze the option in the View menu. There should be an option under option to disable thumbnails alpha though. Would be helpfull, hope you include it in future versions.
Thanks a lot.
