Hello!
Is there a way to compare folders using XnView? So far I didn't manage to open two instances of the Browser, thus I have to use Total Commander or just Windows folders side by side.
Thanks.
How to compare folders?
Peter2
Re: How to compare folders?
vitar wrote:... So far I didn't manage to open two instances of the Browser, ...
Have you disabled
"Options - Category: General - Tab: Operations - First command: Only one instance"Good idea.vitar wrote:...I have to use Total Commander ...
Maybe not a good idea.vitar wrote:....or just Windows folders side by side....
You could also use Winmerge (freeware): http://winmerge.org/?lang=en
IMHO compare folders / synchronization could be a rather complex thing, and this is always the point where I would say:
Where is the separation between an "Image Tool" and a "File Manager"? Maybe this feature belongs to specialized file tools. But this is only my personal opinion.
Peter
vitar
Thanks! Good idea, I forgot about it. I was trying to open two browsers inside the main window.Peter2 wrote: Have you disabledCode: Select all
Unfortunately TC builds thumbnails very slowly, thus it is not very convenient for visual comparison.Peter2 wrote:Good idea.vitar wrote:...I have to use Total Commander ...
You are right, but XnView is actually an Image File ManagerPeter2 wrote:IMHO compare folders / synchronization could be a rather complex thing, and this is always the point where I would say:
- Forum Librarian
JohnFredC ([url=http://newsgroup.xnview.com/viewtopic.php?p=71684#p71684]Dual pane file browser [with visuals]...[/url]) wrote:How I currently use XnView (MP shown):
- Second Browser/File List Window
- File compare for non-image files
- Renewed Request: Dual Browsers
- Enhancement to Compare
- Find Similar Files suggestions
- Similarity index improvements
- A Dual Panel XnView System
- XnView "Hypervisor"
- Split screen browser for 2 folders at once?
- Opening xnview *browser* with a list of files
- XnMP: Sub-tabs in 'Browser' for a File Manager environment
- Search images in another set of images
- [Request] Add Folders as Tabs
