Hi
Not sure if this is the right forum or not but would like help on using XnView to download photos from my camera.
I was using Win XP and found the download wizard great.
However the donload function on Win 7 is awful and i am looking for an alternative were I can choose the photos I want to down load.
If Xbnview has this function how do you use it, if not can i be pointed in the right direction.
thanks
Bernard
Downloading photos on Win 7
- Forum Librarian
Re: Downloading photos on Win 7
Have you tried XnView Media Detector (XnViewMediaDetector.exe)?
berniebee
I have downloaded it as the full package from the link you gave me.
Selected "media detector"as on of the components but it is not showing in Win 7 or as a option when I plug in my camera.
I am using Win 7.
Thanks
Bernard
I am using Win 7.
Thanks
Bernard
- Forum Librarian
Is the Add XnView to applications for USB events (camera, scan, ...) setting (Tools » Options... » System integration » Integration) activated?
xnview ([url=http://newsgroup.xnview.com/viewtopic.php?p=68312#p68312]XnView Media Detector[/url]) wrote:I'm really sorry, i'm very busy currently. I'll try to work on MediaDetector for next release of XnViewgclunsf wrote:Can you give some idea where this stands relative to other XnView priorities? I also would like to know where the issue of Media Detector reacting to USB events stands as well. Currently, I have to manually start it whenever I load a memory (SD, CF, etc.) card on a USB-attached reader.
berniebee
Sorry you have confused me here.
I think you are saying that Media director is a work in progress and you will work on it when you have time ?
All I want to do is plug my camera in to the computer and download my photos
- Forum Librarian
Well, XnView should show up in the AutoPlay dialog box, but you have to activate the setting mentioned in my previous post.berniebee wrote:All I want to do is plug my camera in to the computer and download my photos
I'm just an ordinary user like you. Pierre is the developer of XnView.berniebee wrote:I think you are saying that Media director is a work in progress and you will work on it when you have time ?
Related topics:
- XnView Forum
- TechTalkz.com Forums
